If you completely drag down the bottom frame, you can’t retrieve anymore.
The up/down dynamic cursor never appear. You have to restart app. to recover it
- The bug / behavior you have encountered
- Your system profile
- Your log files (Help > Logging > Get Logs for Support)
- Any screenshots as necessary
Are you referring to resizing the entire app window?
I dragged it to the top bottom.
On first try it locks 5 pixel from bottom.
If you catch it again, and again drag it to top bottom it does go to bottom but cursor vanished, nor more possible to reup it
I did while I was encoding so I can’t reproduce it untill 22hour else I ruine my job
- Drag the frame down " Source + Previewe/Export frame" until the cursor allows it. (around 3 pixel from top bottom).
- Repeat the same drag down, now the cursor can go to full bottom, release. " Source + Previewe/Export frame" is completely filling the screen.
- Try to catch back this frame to reup it : Impossible. It was possible in all previous version. So Topaz bugged it while introducing new timeline.
This equals “Full screen view” + “Show pannel” from menus
EDIT : Temporary solution found CTR+F and CTR+F
Thanks for that additional info, I’ve just confirmed this and put in a bug report on our end!
