TVAI 3.1.x slower than 3.0.x
Anyone having TVAI 3.1.x running slower than 3.0.x or 2.6.4 please post the following information below.
CPU, RAM, GPU, VRAM, input resolution, model used, output resolution, fps or slow motion amount, spf/total time taken in both versions.
If the amount is significant please try reducing the Max Memory setting to around 75% and try again.
Tried with a low end PC.
CPU: I7 7700
RAM: 16gb
GPU: NVIDIA GTX 1060
VRAM: 6gb
OS: Windows 10
TVAI version: 3.1.0
Model: Proteus v3
Input Resolution: 1080p
Output Resolution: 1080p (only enhancing with relative to auto)
100%: 0.9fps
75%: 0.5fps
Hi, I made a comparison with the same video 720 x 576 50 fps, with artemis medium, a comparison in my original size, and a comparison in x2 upscale, 2.6.4 is much faster, I don’t understand nothing … I tried to lower the vram to 75%, even lower, nothing changes. I have a gtx 1660, a ryzen 7 2700 and 16gb of ram.
I will do some tests tonight with 3.1.1 vs 3.0.12 and post results.
@suraj
Good news, and some bad news!
Testing complete, in summary, v3.1.1 is faster with Artemis and Proteus Auto (didn’t test other enhancement models) than v3.0.12. However, Chronos Fast performance in v3.1.1 is about 25 to 30% slower, or in the case of a 4k input source, will still crash Windows with a BSOD. Also, I did not get the 4x slowdowns on Chronos Fast that were present on v3.1.0, so performance has improved in v3.1.1 but still lags v3.0.12.
OS: Windows 11, Nvidia Studio Driver 528.02
GPU: GTX 1070 8GB VRAM
CPU: Intel 6700K
System RAM: 16GB
Max memory set to 100% in Video AI preferences
3.0.12:
Input source: 3840x2160 30 FPS:
2x Chronos Fast to 60 FPS conversion:
1.30 spf
Artemis High, no FPS conversion:
2.40 spf
Proteus Auto, no FPS conversion:
2.88 spf
Input source: 1920x1080 29.97 FPS:
2x Chronos Fast to 59.94 FPS conversion:
0.33 spf
0.57 spf
0.60 spf
3.1.1:
Max memory set to 100% in Video AI preferences, Windows BSOD/hard crash!
Max memory set to 80%:
1.65 spf
Max memory set back to 100% in Video AI preferences for following testing as only Chronos Fast 2x on a 4k source seems to crash Windows when max memory usage is set to 100%.
2.14 spf
2.47 spf
0.50 spf
0.45 spf
0.49 spf
Fortunately, v3.1 is vastly superior here, speed-wise, to the v3.0 series. But why would assigning more memory decrease speed in the first place? Paging?
Change the size of memory does nothing.
Model: V2.6.4 RAM VRAM CPU-Load GPU-Load
Sec/frame MB MB
Proteus 0.12 15300 2629 10-20% 2-94%
Artemis LQ 0.09 15300 2690 8-30% 5-90%
Chronos v3 f 0.03 14500 1718 19-38% 6-8%
Stabilisation
Gaia HQ 0.12 15500 3847 5-20% 20-90%
Model: V3.0.12 RAM VRAM CPU-Load GPU-Load
Sec/frame MB MB
Proteus 0.15 16300 3911 9-15% 5-45%
Artemis LQ 0.12 15900 3802 13-20% 8-70%
Chronos v3 f 0.12 16300 4054 10-18% 6-60%
Stabilisation 0.41 16500 5421 5-15% 9-60%
Gaia HQ 0.07 16000 4817 12-20% 6-100%
Model: V3.1.1 RAM VRAM CPU-Load GPU-Load
Sec/frame MB MB
Proteus 0.12 15400 4726 6-13% 6-80%
Artemis LQ 0.08 15300 4581 3-10% 30-70%
Chronos v3 f 0.07 15600 5643 8-15% 30-70%
Stabilisation 0.11 16300 6727 5-15% 30-80%
Gaia HQ 0.09 15300 5956 5-10% 50-98%
Closed no active APP Closed no active APP
RAM VRAM
13424 1215
Input File:
Res: 720x576
Format: .mov
output: File:
Res: 1080p
Format: .mp4
188% scale H.264 (AMD)
Sys specs:
CPU AMD Threadripper 3960X 128 GB ECC on SMT off 24 cores only
GPU AMD Radeon PRO W6800 32GB ECC on
OS Microsoft Windows 11 Pro for Workstations
Version 10.0.22621 Build 22621
MainBoard PRIME TRX40-PRO
Radeon PRO GPU Driver V22.11.2 Date 30.11.22
GPU Memory Visualisation while Proteus is processing.
Visualisation of Proteus while export
TVAI uses about 1.3G (an upscale to 4K), ffmpeg ca. 5G.
Found the issue here and fixed it. Performance should be 5-25% better than 2.6.4 with todays beta. Looking into others.
In some cases especially for cards with lower vram, swapping from ram to vram happens a lot more leading to slow downs.
Thanks for getting back to me on this one. It’s appreciated.
That means boards + GPUs with both pci-e 4 will be faster.
that’s great! thank you very much!
Updated Numbers with a Intel Nvidia system, just for comparison.
I’ve to retest the AMD sys with the beta, i did turn off Freq-enhance, so tested with lower freq. :dizzy_face:
AMD Threadripper 3960X|128 GB ECC on SMT off 24 cores only
Main Board PRIME TRX40-PRO
Model: V3.1.2.0.b RAM VRAM CPU-Load GPU-Load 10 sec preview AI-Processor
Time:
Mem = 50%
Sec/frame MB MB
Proteus 0.09 15700 2657 20-35% 2-94% 56 sec Auto
Artemis LQ 0.08 15700 2625 8-30% 5-90% 49 sec Auto
Chronos v3 f 0.08 15800 4945 19-38% 2-94% 47 sec Auto
Stabilisation 0.22 16123 3861 12-30% 60-80% 1m45sec Auto
Gaia HQ 0.08 15700 6204 5-20% 60-90% 43 sec Auto
Just for Comparison
Nvidia Quadro RTX 5000 / 16GB VRAM (like 2080S), Driver: 528.24
Intel 7820X, 8C/16T, 64 GB Ram
Win 11, PRO
Time:
Mem = 50%
Sec/frame MB MB
Proteus 0.05 11715 2584 12-20% 40-50% 30 sec Auto
Artemis LQ 0.04 11234 2461 12-20% 60-66% 22 sec Auto
Chronos v3 f 0.04 11584 3075 12-24% 55-62% 37 sec Auto
Stabilisation 0.12 12200 4816 16-30% 30-45% 1m40sec Auto
Gaia HQ 0.08 10899 3763 9-16% 95-97% 45 sec Auto
Model: V3.1.1 AMD sys RAM VRAM CPU-Load GPU-Load 10 sec preview AI-Processor
Mem = 50%
Sec/frame MB MB
Proteus 0.11 16100 5183 6-13% 6-80% 58 sec Auto
Artemis LQ 0.08 15900 5071 13-30% 30-70% 46 sec Auto
Chronos v3 f 0.07 16200 6100 20-30% 30-70% 58 sec Auto
Stabilisation 0.11 17200 7200 20-30% 30-80% 1m45sec Auto
Gaia HQ 0.08 15400 6420 10-20% 50-98% 48 sec Auto
output: File:
Res: 1080p
Format: .mp4
188% scale H.264 (AMD/Nvidia)
Here is a version for anyone with the issue to test
This topic was automatically closed after 5 minutes. New replies are no longer allowed.
