Tutorials for v4.0.8
I am brand new to VideoAI. Where can I find video tutorials that are specific to learning how to use the software? I assume the majority of videos would be available on YouTube. Thanks
Same request…New to video AI and want to use it to address home made videos from the mid 80s to early 90s shot with Sony on betamax, and then canon on Hi 8, iirc, and later digitized to mp4s which are my source files for Video AI.
I’ve played with it a bit and found that increasing resolution to 1080 is a real time hog, but it does deliver 1080 from the original 480. Getting artifacts especially on skin. Still, I could use some tips in usage, things to avoid, how not to over do it, best practices, that sort of thing.
Video AI speaks a different language that, unfortunately, I don’t find intuitive.
Appreciate any advice. and TIA
It is not easy to give general tips here because every video is unique and may demand individual settings for the best result. Maybe you offer an example for download so we can give it a try?
Same request. I am trying to work with home video from the 70’s and as there are different AI models, I have no idea which ones to chose or tweak.
Thanks. I understand that one size doesn’t fit all. I found a video on youtube that has helped
https://www.youtube.com/watch?v=m7uCZoDKn_I
It is for a previous version, but still addresses the questions I have.
Part of my problem was the enhancement from 480 to 1080 taking a LOT of time. I am doing 720 now and that is likely adequate; still need to review. Also doing previews in a number of configs made it clear which setting to use on the video I was working on. I was previously only loading one preview at a time; loading a number of them provides clear comparisons. 720 takes only 25% of the time 1080 took.
I think I can proceed from here…I think.
Thanks
