Trying Video AI to reduce noise
I used Enhancement Artemis High Quality to reduce noise in a 5120x2700 short footage.
I don’t see any changes, noise seems the same. I am looking at the dusk sky.
Thanks
I have found that Artemis Medium Quality works great on FHD or smaller videos. I don’t have anything bigger, so I don’t know about your mentioned resolution.
I think the nomenclature refers to the source material - ie. Artemis HQ is for original material which is HQ in the first place so does less processing to fix it - not so much to fix. Artemis Low Quality rips out all the noise but you also get softening and detail reduction in the process - it is of course possible to have UHD thats noisy or SD equally so -
Paul :slight_smile:
