I have recently transitioned from a PC to a Mac studio running Sonoma 14.1. I have downloaded the Topaz Plugins that I own: Photo AI, Sharpen AI, Mask AI, Adjust AI, Texture Effects 2, and Studio 2. I have them all dowloaded them all to my hard drive and then installed and moved to the Photoshop Applications folder.
When I open Photoshop and want to work on an image, the only Topaz plugins I see are Sharpen AI and Photo AI. All the others will open in stand alone EXCEPT Adjust. It simply crashes. But I can not get them to show up in my Photoshop.
Any ideas?
Let’s start with Topaz Photo AI.
I’d like to get some more information to help troubleshoot the problem you are having.
Could you send us your computer’s full system profile?
Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
Thanks so much for being willing to help. The fix was simple, several of the plugins were discontinued and don’t work on newer operating systems. As for the others, I had to go into setting and Open with Rosetta. That was the fix!
