Clicking the blue “Render 2s” produces an error that is not explained.
M4 Max Mac Studio; macOS 15.5
logsForSupport.zip (129.1 KB)
This appears to be a permissions issue;
Make sure that the export path you are writing out to is readable and writable by Topaz Video AI and that the path exists.
Try adding Video AI to the list of apps with ‘Full Disk Access’ in the macOS System Settings and restarting the app after: If this does not work, please proceed to a clean install which should reset the app’s permissions.
