So now not only are we experiencing all these updates you have now decided to move all the controls around, changed the order!! Why? Not sure if anyone else feels the same but they were fine just as they were ;-/
We updated the right side controls as this should more accurately show you what Topaz Photo AI is doing and make it easier to use.
It may take a bit getting used to, however it is clearer than the previous design once you are familiar.
