Topaz Video 1.7.1 on a maxed out Mac M3 Studio Ultra 27.0.1. A Starlight Precise 2.6 render is stuck.
a. Loading model is frozen at 32% with no CPU or GPU activity
b. Stop processing does nothing
c. Close video does nothing. “want to remove” hit yes and nothing happens
d. Uninstalled and reinstalled
e. Removed preferences
Render is still stuck and un-removable.
logsForSupport.zip (251.9 KB)
The team is actively working on some compatibility issues we are seeing with macOS 27 and release version 1.7.1.
However, the only command line I am seeing in these logs is from version 1.6.1 run back on the 5th, and that shows the app trying to load but never completing the model start-up phase. It does not show an error code, but does show that the process was stopped about a minute later.
Since you already tried a reinstall, we can try a different approach from within the current version of the app to see if that changes the outcome. In the app, click on the Neuroserver model manager and remove the model file, and then have the app download a new version.
If not, please share the updated logs and we can investigate further.
Removed Starlight Precise and added it back in, quit the program and started it up again.
Unfortunately no change, export is still in progress and stuck at 32%. Can’t stop it or close it.
logsForSupport.zip (322.9 KB)
What is odd in this situation is the logs are not showing a command process even queued up to run on the system. If you can grab a screenshot of the export queue and post here, or you can send to help@topazlabs.com for review. This could be a different situation that is stemming from the macOS 27.
Started it up again. It couldn’t find the file for some reason and that cleared the hung export. Now it is working after adding the same file back into the export.
So it looks as if when an export hangs and it can’t be cleared if you move the source file so it can’t be found the hung export will then abort.
Sometimes in that kind of a situation, starting a new project can work as well as that resets everything to a default.
win11 ent 25h2. 9800x3d, 5090, 32gb ddr5, p5800x optane. also stuck on loading model ,waiting.
Can you grab the logs from your system and send into the support team at help@topazlabs.com?
