Topaz Video Al v3.2.4 not working on M1 Max
Experiencing the same on MacBook Air M1
Latest version is not working unknown error no matter what the video asset is used or settings used.
Hello,
I’ll need to look through the app’s log files to see what exactly is causing the error:
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the zip file to your reply.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
