I have been testing the Intel ARC A380 with topaz labs Video A.I. I see there are issues here with 4080 and 4090 cards and not being able to use more then 10% of the GPU. I have a 3090 system with a i9-11900k and I have a slightly same issue but I think I have resolved this issue with the testing I did on the A380( The A380 system is a i9-13900K).
I lowered the ram settings in Topaz Video AI to 25 percent and that has caused the A380 or the 3090 to use over 95% Utilization from the task manager stats. Both systems have 64GB DDR4 Ram and are using M.2 NVME PCIE 4.0, that being said when lowering the ram settings it all falls on your GPU and the rest may not matter as much when encoding or decoding at least my testing has proven this. Now to show what the AV1 encoder can do, it is by far more efficient in Topaz then Handbrake.
Video Information
Original
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 35 min 59 s
Bit rate : 32.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.154
Stream size : 8.03 GiB (99%)
Color range : Limited
Color primaries : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
AV1 Conversion
Format : AV1
Format/Info : AOMedia Video 1
Format profile : Main@L5.0
Codec ID : V_AV1
Color space : YUV
Bit depth : 8 bits
Stream Size :697MB
Writing library : Lavc59.56.100 av1_qsv
Default : Yes
Forced : No
