- every time i try use NYx fro denosing it fails with error
- i have Windows 11 and RTX 5090
logsForSupport.zip (39.7 KB)
The logs are showing an illegal memory error causing the issue, try the settings below and check to ensure that you have the latest Studio Driver installed from the NVIDIA drivers update page.
File>Preferences>Processing
- Ensure that your GPU is selected for the AI Processor
- Set the max memory to 80%
- Set max processes to 1
- Save the settings and close the panel.
- Re-run your clip through the process that you were trying.
