Fixes the frame interpolation models repeating frames when changing FPS.
Reduces model loading time for Nyx, Proteus, Iris Auto and Relative to Auto.
Fixes stabilization not running on lower memory machines.
Fix crashes related to image sequence fps change.
Add warning when rotating after setting crop dimensions.
Add 10-bit for NVENC AV1.
Automatic parameter estimation now runs on 8 frames instead of 20.
Nyx as second enhancement will now automatically make the first enhancement perform upscaling.
Iris-v2 is supported on Intel ARC.
Attention: The format for support logs is being changed to include license information (auth.tpz). While this file is encrypted and only useful on your machine, please try to avoid posting it or your support logs here by mistake. This would not likely lead to a problem, but better to be safe than sorry. Please submit any logs directly to our support team or devs.
Known Issues:
Currently not all the models are supported on Intel ARC. (Model support will be added week to week).
Videos with mismatched metadata and streams will display incorrect duration
Frame number preview length may shorten on app restart
Gonna have to look at getting a new GPU soon and those Intel ARCs are priced pretty well for 16gb cards. Not sure how well they perform or if they really work much at all in Linux, any work on Intel or AMD GPUs on the Linux version?
We are working with intel very closely to resolve issues with running models on ARC on their latest frameworks and drivers.
Currently we only have confirmation that Iris-v2 works as expected. We will be making sure all models work one at a time and make necessary changes to make them all work over the next few weeks.
This doesn’t mean that other models do not work, it just means certain models have been confirmed to work correctly.
I have not fired up Video AI Beta in a while, but when I went to use it I am now getting a watermark. I purged all installs of Video AI (alpha and beta), reinstalled this version, but am still getting the watermark. I checked my license and I am good until spring of next year. I went on the command line and used the videoaiBETA-login tool and confirmed I am getting back a token. It is almost like the token cannot be stored, any ideas?
“Replace duplicate frames” (or triple or quadruple frames or …) does not work properly. I think on the most sensitive setting it should get rid of any double/triple/quadruple looking… frame and interpolate a nice and smooth motion.
Love the attention towards fixing frame interpolation, testing time! Please consider variable frame rate videos as an input as well - this way we could convert them to the constant frame rate ones with fluid smooth motion!
I had that happen with nostrils, but yeah, my guess is that it’s much like us when we can make out faces/shapes in the clouds, so it’s matching the eyes to something that it interprets as representing facial features…
Preview button working on Mac Studio M1 Max (was inactive with public release of 3.5).
Enhanced ~10 videos with 4x Iris v2, now my favorite model. Mostly 360p, getting ~ 3 - 3.5fps. not great but worth the wait with enhancements provided by Iris
