@xuan.liu Color Noise in Video getting Blurred should be black.
This build still leaves an exported temp file.
So a final export file and a temp file in the export folder.
Didnāt notice much difference in the preview experience, but I did notice a big performance hit on Artemis and Proteus:
Topaz Video AI Alpha v3.2.1.3.a
System Information
OS: Windows v10.2009
CPU: AMD Ryzen 7 2700X Eight-Core Processor 15.939 GB
GPU: NVIDIA GeForce GTX 1060 6GB 5.9014 GB
Processing Settings: device: 0 vram: 1 instances: 0
Input Resolution: 1280x720
Benchmark Results
Artemis 1X: 1.08 fps 2X: 0.69 fps 4X: 0.27 fps
Proteus 1X: 1.12 fps 2X: 0.74 fps 4X: 0.94 fps
Gaia 1X: 1.36 fps 2X: 0.92 fps 4X: 0.66 fps
4X Slowmo Apollo: 4.20 fps Chronos: 2.29 fps Chronos Fast: 3.71 fps
Topaz Video AI v3.2.0
System Information
Benchmark Results
Artemis 1X: 3.76 fps 2X: 2.57 fps 4X: 1.03 fps
Proteus 1X: 3.63 fps 2X: 2.50 fps 4X: 1.02 fps
Gaia 1X: 1.35 fps 2X: 0.91 fps 4X: 0.65 fps
4X Slowmo Apollo: 4.20 fps Chronos: 2.29 fps Chronos Fast: 3.70 fps
I get an error with this settings.
I donāt get it to work with āreduce jittery motionā.
Download takes forever and does not finish.
The same for the Beta.
Can u please add āframe # display modeā? Iām so tired of having to only use time display mode, computer turning off from electricity outage or something, then having to restart the ENTIRE video all the way over again (taking days of wasted workflow) since I never know the exact frame I was on.
I need this for exporting the frames into PNG format. I never know what the last frame exported was within the program. Only in Windows Explorer. So when my computer crashes/outage, I have to literally delete 10s of thousands (ALL) the exported frames and reupscale the entire video from very beginning all over again when if ur program had the frame display mode, I could just start from the last frame # exported (if the last PNG frame exported was 110,567 in Windows Explorer, I could just go to frame # 110,568 and start the upscaling process from there. I canāt do this if ur program now only shows the time of video. I need the exact frame). Video Enhance used to have this in 2.0 versions. U guys took it away in all 3 versions so far. There r people that canāt go days of re-upscaling something from power outages or computer crashes. I live in a state that gets lots of thunderstorms. Thank you
I greatly support the request. Adding frame numbers in addition to the time stamps does not sound like rocket science to me. Making a precise cut or just continue where I stopped processing via time stamps is a real pain.
