Topaz Video AI 5.3.3 loses AI model selection
I’ve set up everything as in the screenshot ‘topaz-video-ai-533-proteus-set’ including Proteus with activated parameters as AI model.
If I close and reopen/reload the project or if I have multiple clips under sources and copy/paste the settings to the other clips, everything stays as it should but the AI model. That is always reset to Dione Robust (no parameters) again, regardless what I do.
Because of that it then renders with Dione, too, then. So I always have to switch AI model manual for every clip every time. That’s far more than annoying.
2. Your system profile
Windows DisplayVersion: 22H2
WINDOWS VERSION IS 10.22
VNNI: 0 AVX: 1 CPUName: AMD Ryzen 7 3700X 8-Core Processor Thread Count: 16
MEM TOTAL: 31.9136 AVAIL: 13.6594
1 Device Id: 0 Name: NVIDIA GeForce RTX 4060 Ti VRAM: 15.7314 GB
2 Device Id: 1 Name: Microsoft Basic Render Driver VRAM: 0 GB
0 Device Id: 1 Name: NVIDIA GeForce RTX 4060 Ti VRAM: 1.71752e+10 GB
=== System Information ===
OS Windows Version 10.22
CPU AMD Ryzen 7 3700X 8-Core Processor Threads 16 AVX 1 AVX2 1 VNNI 0
RAM 31.9136 GB Total / 18.2541 Free/Used
1 Device Id: 0 Name: NVIDIA GeForce RTX 4060 Ti VRAM: 15.7314 GB DataType: 2
2 Device Id: 1 Name: Microsoft Basic Render Driver VRAM: 0 GB DataType: 2
Creating file fetcher for: https://veai-models.topazlabs.com REMOTE DIR: /
AIEngine mode: Normal 3.1.11
ModelManager: setting modeldirPath: C:\ProgramData\Topaz Labs LLC\Topaz Video AI\models
File Fetcher setting localDirPath to C:\ProgramData\Topaz Labs LLC\Topaz Video AI\models\
Don’t think it makes sense to copy that whole log in here because it’s quite much text and there are also personal informations in it. I also don’t get any error message and everything else works. It’s just that one parameter which doesn’t get saved when set.
I’ve searched before but didn’t find it.
Thank you for sharing the screenshot wiith us, we are aware of this bug and the team is working on patching this issue as quickly as they can.
