I’m often not happy with Vignettes. I’m not always sure of what part of the picture will ultimately be the most important. Especially with Gigapixel AI, my options for using parts of a picture have increased. I would like to have a button to simply exclude vignetting from all the filter recipes.
Topaz Studio only applies a Vignette if it is in a Preset or you apply the Vignette Adjustment … you can disable the Adjustment by clicking on the eye icon if it is in a preset.
Yes. But as a request, I’d like a slider or something to simply not implement vignettes in any effect I choose. So if I try a bunch of effects - I can simply see them without the vignettes.
