Recently I am having a problem using a pen with Studio. I am having a number of problems.
- As soon as I touch the pen anywhere in the center screen area, It zooms to to maximum-sometimes off screen. I can use the pen to reveal the whole image by using the fit command. As soon as i touch the screen area with the pen it repeats the behavior.
- On the left hand side of the app in the effect selection area, I can select an effect, but I can’t scroll down using the scroll bar on the left hand side.
- On the right hand side, when I try to modify an effect by sliding the horizontal scroll bar, it won’t let me. It will jump from one value to the next, but it won’t scroll like it does with a mouse.
Am Uptodate wit Windows 10 and wacom drivers. Any suggetions
