I can’t see a way for Studio Digital Frame to draw on textures other than the ones that come with this adjustment itself. I would like to use custom textures I have stored in Studio in the Textures Manager.
Is there a way ? or Can I add that to a feature request please?
I think a work around is to use Textures on the image with the Matt, invert the mask and mask in the texture. Change the round brush into a square then you will have sharp corners.
Thanks for the detailed explanation. will give that a go.
Would be great to eventually have the choice within the frame menu to add a custom texture. However I guess they have a long and growing list and not a huge staff to deliver!
Hello Ricci, this caught my attention.
Is this possible with the stand alone Studio??
Thanks,
John
@JohnG50D Yes it will work on the stand alone, make sure you have the latest update. On this image I have a texture over the frame and masked out the center
