Updated Topaz Studio 2 and now Impression, AIRemix and Texture filters don’t appear to be functioning
I don’t recall if you’re on a Mac… I just tried on a Win 10 box and they seem to work correctly.
Studio 2 v2.02
I am sure a version number and a platform (Win/Mac) would be helpful. v 2.0.2?
Same here. Checked mine out and all seem good. WIN 10
Interesting issue. I tried stand alone on a JPG and a TIF, both fine. Then called Studio 2 from LR, also fine.
Curious to see what’s causing it not to work for you. And also what you’re going to do with the pretty rose.
Hi Sharon, It doesn’t seem to be a GPU issue as I tried it on both Intel & NVIDIA. Try rebooting your PC and if it doesn’t work after that then raise a support request.
@ScottO … not exactly sure what was going to be the outcome for the roses … that’s the fun of Studio
good news all … after uninstalling and reinstalling I can once again use Impression, Texture and AIRemix … yay
Very strange. Keep an eye on it. Let us know if it happens again.
will do
