Topaz stopped working
The programm just freezes, it was working fine after I paid and downloaded it today and now it already stopped working, it froze, I tried restarting and it just doesn’t work. Please help!
Please make a clean uninstall, downlaod the latest version and make a fresh install:
Hi, Imo, I did a clean uninstall and reinstall and still get the same. All the buttons are either unresponsive or the whole program just freezes. I am so sad as I love your program! What else can I try? I am on Mac Ventura 13.5.1 (22G90).
If it isn’t working I am afraid I will have to ask for a refund as that is a lot of money for something that worked once and not again. :(((
Greta
Hello Greta, please write to help@topazlabs.com
The Topaz team normally responds quickly. :slight_smile:
Topaz Labs Download Page
If you are still experiencing problems after following these steps please reach out to us at the following link:
Topaz Labs | Support Page
Are you guys kidding about those instructions? The product was purchased and the expectation is that it works. I don’t have the time … nor should a normal consumer … have the time to run through a detailed list of instructions that may or may not be easily accomplished. The program has ceased to be operational on my MacBook Pro with an M1 chip. It freezes within photos when using the editing function. The drag and drop just doesn’t work period. What’s the story, folks? I love the program but am extremely disappointed right now that there is not a simple solution.
Please follow the instructions below to fix this issue:
Topaz Photo AI Freezes on Importing Image (Mac)
This topic was automatically closed after 49 days. New replies are no longer allowed.
