Hi,
Has anyone had any experience? Does it really speed the AI scaling?
Any comments will be helpful to help us decide if it’s worth it.
Hi,
Most cloud hosting servers are designed for CPU-intensive operations rather than GPU-intensive. So I wouldn’t expect a performance improvement over a local system with a good GPU. You’d be better off looking into cloud GPU providers.
I found Hyperstack, that should do.
Don’t think I’ve seen any mention of how the app works with H100 processors. Would be interesting to see benchmarks.
Will do.
Not mine, just seems like a good one with reasonable rates.
