I’ve downloaded the trial version and so far the software runs for an average of 6 minutes until 100% and then crashes without generating a denoised file, but instead the original file is affected/damaged.
did you guys find a fix for it ?
it worked fine a few times but crashes 9/10 times, although I’m happy the results the very few times it worked, I will not be buying the licensed version (and the paid upgrade) until a functioning version is released.
thank you
