Topaz Photo AI v3.0.1
Hi,
My usual method is to export an image from the MacBook Photos app to Topaz AI for denoising and sharpening and then export back to Photos app where I do cropping before saving the image in the folder.
After the upgrade, I am unable to save the edited image to photos app.
I am using MacBook Pro 2018.
Anny suggestion?
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Topaz Labs Download Page
