Hello everyone!
This week’s early access update features a major update to the auto pilot experience. It will now always be enabled, but you can freely change any settings off the suggested values. It will also be more clear as to what it has already detected and what it’s currently working on - and will even show you the detected subject and faces, when appropriate! There’s a good number of other fixes and improvements to explore in this week’s update as well.
One more note: We anticipate some confusion about this now that we display the subject to the user, but to be clear that is currently only used for determining which filters should be enabled. None of the filters currently use the subject mask - although you can expect that to change in a future EA update.
If you own DeNoise, Sharpen, and Gigapixel with up-to-date licenses then you have access to Photo AI. You will need to claim a Photo AI license by going to your account before you’ll be able to login.
Released August 4th, 2022
Mac: Download
Windows: Download
This is an early access release, so there will be some issues you may run across. Issue reports and general feedback are much appreciated. If there’s a specific image you’d like us to see, you can send it to us at this dropbox link. Below the changelog are a list of issues we’re already aware of.
Changes since 0.4.0:
- Added mask and face detection previews when hovering over the respective icons in Autopilot
- Changed settings so that they are no longer locked when Autopilot is active and will show suggested values inside control settings
- Changed some messaging in the login dialog for when login isn’t valid
- Increased performance for face refinement
- Fixed issue where batch save would stop after a certain amount of images
- Fixed issue with view mode toggle not selecting correctly
- Fixed several issues with batch file view selections/settings display
- Fixed image position centering and zoom resetting when switching view modes
- Fixed color issues with face refinement
Known Issues:
- The first time an image is selected, the autopilot values will replace any values set manually via the “Apply settings to all” feature
