Topaz Photo AI v 2.3.2
I’ve been using Topaz Photo AI for some time with great success. I use it with my Apple Mac photo-editing software and press the 'three dots ’ to invoke Topaz from Apple editing. A couple of days ago everything ground to a halt and I can no longer use it. Loading photos is extremely slow and I can no longer edit them.
I’ve tried look at CPU/GPU in preferences / general but the software does not respond. I’ve also tried reloading Topaz Photo AI but have there same issue.
Any suggestions?
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Topaz Labs Download Page
