Topaz Photo AI Unresponsive
with the last two updated to Topaz Photo AI, the application is pretty much un-usable. When I use the plug-in to import the my photo from Adobe Lightroom, the application hangs for a long time. Once the photo appears in Lightroom, its pretty unresponsive. I have tried to uninstall and reinstall, but issue still persists.
What are your system specifications. OS, RAM, CPU, GPU, vRAM
macOS Sonoma 14.2.1, 2.4 GHz 8-Core Intel Core i9, 64 GB Ram.
Please make sure that you have all plugins such as Lightroom fully closed before proceeding
Topaz Labs Download Page
Let me know how that goes for you.
