Topaz Photo AI , showing shadows on photos, Sony A6700
Using Topaz Photo Ai auto setting on a photo imported from Lightroom ( file - plugin extras - process with Topaz Photo AI )
lightroom version - 12.5
Topaz photo AI version - 1.5.4
Once topaz photo AI does its stuff and returns the photo into lightroom, the photo has a bright shadow in the photo, this is happening with all photos…
Is there a workaround for this or an update coming for it?
Camera is the Sony A6700.
Thanks for reaching out. If there is mask and crop on the original image then this issue may happen.
If you would like to keep the mask and other edits that you have already made to the image, I would recommend using the Photo > Edit in > Topaz Photo AI method.
The recommended workflow is to take the original image and use the File > Plug-in Extras > Process with Topaz Photo AI workflow before you make any edits to the image.
Let me know if you have any questions about this.
