I miss the opportunity to set the following scaling feature: Resize to fit the long edge & Resize to fit the short edge.
That will make scaling much more effective. If you e.g. have shot an image series in both Portrait and Landscape format, then you can rescale all the images in one go. As it is now, you will have to do that separately for each format. A lot of pro editors have this feature.
Thank you for an otherwise great app.
All the best, Svend B Sorensen
Innovator of 3D & Visual Tech at SBS 3D LAB
