Topaz Photo AI Not Resizing on Export
I’m going through all the steps I normally do to resize an image, and on export, it does not resize it. I add a crop, and the exported version is cropped as I want but is not resized. I’ve restarted the software and rebooted my Mac. Still no luck. Any ideas? This all started with the newest release download. I’m trying to include screenshots but see no way to do that.
2.4.0 Topaz Mac resize the original photo to your desired size, then only crop the resized photo. Hence the photo generated is much more smaller then the size you set (cropped).
The process suppose to crop the photo first, then resize the cropped photo.
Huge software Bug that shouldn’t happen!.
Topaz Labs | Support Page
not resolved. even version 2.4.2 still not solve the problem.
Please reach out to us at the following link:
