Topaz Photo AI is introducing undesirable artifacts
[starting in lightroom, then Edit in Topaz Photo AI, i noticed lately that artifacts are shown in the picture, as if you are using a laso tool and forgot to exit it…
the thing is that the final image is keeping the artifacts.
any idea.]
Note: ive been using Photo AI for around 1 year, never had this before
i am keeping the system always updated
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Same here. Seeing strong aliasing and moiré patterns in the preview. I expect it has to do with the down-sampling filter used to scale high resolution images to a smaller resolution viewport.
It looks like a computationally cheap interpolative filter is used, e.g. nearest-neighbour.
Even a (still cheap) bilinear filter would look better. Using a windowed sinc (Lanczos) filter would be best for shrinking/zooming out.
Alias was a problem of scaling in windows in the past.
Scaling is already at 100%, so that’s not it. It is something in the Topaz UI/preview rendering, because the saved output when viewed in an image viewer (with proper downsampling) does not show the issue.
Hey @fadi.el_khoury, can you share your screenshot + the processed image if it also has the artifacts through our dropbox?
The screenshot here looks a bit compressed, was having trouble pinpointing exactly where the artifact was.
Submit to Dropbox
Thanks!
I submitted the files to dropbox… kindly confirm receiving the files :pray:
Note: 2 days back downloaded the upgraded version
still same issues
Thanks in advance
Dear Preston,
Did you receive the files uploaded to your dropbox?
if yes kindly confirm
Regards
@fadi.el_khoury We did receive them, thank you! @Lingyu will be taking a look as soon as he can :slight_smile:
