Topaz Photo AI glitch
Sometimes (not often), when I want to edit a picture from Capture one, I have this kind of weird areas.
Especially with high iso.
It comes from the noise reduction. Topaz recommend the strong option for this picture but I have this glitch. If I choose normal, it’s ok.
Topaz Photo AI [v1.3.11] on [Mac last os]
Thanks for reaching out and reporting this.
This is a known issue with the Raw Remove Noise - Strong model as you have figured out.
We are updating the Raw Remove Noise models soon which should resolve this.
For now if you see the artifact again you can switch to the Normal model to prevent it.
