Topaz Photo AI keeps crashing (shutting down) after using Remove tool and goes back to Lightroom (which I had been using with Topaz Photo AI).
Topaz Photo AI v2.3.0 on Mac
I have this issue on Windows 11. After using the remove tool, if you open a new image it asks if you want to discard the changes you have made to the existing image. Then when opening the new image it crashes.
Photo AI crashing just before finishing Removal tool
@axel.egilsson @jonv @peter_j.smith
