I use a mac M2 and i try to batch process canon raw files . sometimes i can process 180 files before crash and some times only 15 or just 10 before crash . I started to investigate and i found the reason : topaz photo ai allocates memory but does not release it ! the memory allocation is accumulated until crash .
Steps to reproduce issue:
Step 1 - open topaz photo ai in stand alone mode and open activity monitor - write down how much memory topaz consumes in this idle state ( few Mb only )
Step 2 - open lets say 100 raw raw files and do nothing - write down how much memory topaz is using now … lets say 5Gb …
Step 3 - close all open pictures and clear all recent files - we are now again were we began . idle state , no file loaded files , no recent files - topaz is not doing anything - THE MEOMORY WAS NOT CLEARD ! topaz continues to hold the 5GB …
4.step 4 - open again 100 raw files - check memory , it did not used the 5G already allocated ! check the activity monitor and you will see that now topaz is using 10GB …
topaz will accumulate the memory until all physical and swap memory will consumed and then will crash .
in bach mode - every file processed increase the memory allocation until all physical memory and swap are consumed and will crash .
Topaz Photo AI [v3.0.2] on [Mac M2]
I sent crash logs when it crashed .
then I load some raw images (192 ) and I do ABSOLUTELY NOTING (the only thing that happened is that the auto pilot processed the 1st image )
topaz is using now 5.03 GB
now i “select all” , RMB and “close all images” in addition i CLEAR Recent . Topaz is now at the same state as after invoking NO FILE IS LOADED and No recent files , BUT topaz is still holding all memory , memory was not cleared - this is a server bug imo - no other software on my mac behaves as this . This bug severely hurts my workflow , I don’t know when topaz will crash and all my edits will be lost .
