Topaz Photo AI 3.0.3
Again, for the Fuji Raw files the stand-alone Topaz Photo AI 3.0.3 changed the lighting of the picture .This issue was an older version. The raw file is saved only to a “jpeg” new one.
Please check and do not add the same bugs in your new versions.
With regards
Alex
  1. The original image file.
  2. The processed image.
Dropbox File Request
Hello
I send:
  3. A screenshot of the settings panel
    File Name: DSCF0615.RAF
    Make: FUJIFILM
    Model: X-H2S
    Software: Digital Camera X-H2S Ver6.00
    Date Taken: 2024-06-05 16:03:01
    Exposure Time: 1/100 sec
    F Number: f/3.2
    ISO Speed Ratings: ISO 2000
    Exposure Program: Manual
    Metering Mode: Multi-segment
    Exposure Bias: 0 EV
    Flash: No flash
    Focal Length: 14 mm
    35mm Equivalent: 21 mm
    Lens Model: XF14mmF2.8 R
With regards
Alex
Could you send me a screenshot of the Right Panel enhancements being used on the image instead of the Preferences?
I sanded it.
