Topaz Photo AI 2.4.2 squashing aspect ratio on crop + save
Seems to happen when cropping and rotating.
Original on left, result on right (opened in Photoshop after the fact):
Doesn’t happen if I process the same photo the same way, but leave off the crop/rotate.
  1. The original image file.
  2. The processed image.
  3. A screenshot or description of the settings panel in crop so I can see what adjustments were turned on.
Dropbox File Request
@john.topazlabs I have the original but I already trashed the processed image. I could run the original again and see if I get the same result a third time (I did it twice the first time with similar result). Want that?
That sounds great! Please try to replicate this issue and then send those files over and we can continue to troubleshoot this problem together :slight_smile:
This topic was automatically closed after 57 days. New replies are no longer allowed.
