I am using Topaz photo AI 2.4.2 vision on Mac mini M1, memory 16 GB, storage 500 GB. When i using remove tool Topaz Photo AI unexpectedly closed itself. It looks like crush down, please help me.
No issues for me on my M1 Mac Mini. However, some Mac users have reported crashes and that these can be resolved by deleting the plist files associated with TPAI. Try that first and if it doesn’t work report as a bug with logs etc.
Hello John
Many thanks for your great and useful helping instructions saved my time and works. I did as you mention and it works perfectly.
Have a nice day.
