Topaz Photo AI 2.4.0 Remove leaves figures head and makes it semi transparent gray
Steps to reproduce issue:
  1. Step 1
    When I use Topaz Photo AI’s new remove feature on a person, it leaves only their head and makes it look like semi transparent gray. It does this on every photo and every person I work on.
Is Face Recovery on? If so, you’ll probably have to deselect the faces of people you’re trying to remove.
Topaz Labs | Support Page
