Topaz Photo AI 2.4.0 Crop Fails to Create Cropped Thumbnails
Topaz Photo AI 2.4.0 will crop and export a JPG. The JPG image is cropped. The embedded “Preview” image is cropped.
However, the embedded “Thumbnail” image remains as the original image.
Topaz Photo AI [v2.4.0] on [Mac]
Topaz Labs Download Page
