Topaz Photo AI 2.3.2 on Mac book pro. Has slowed down and keeps freezing
Steps to reproduce issue:
  1. Step 1 Load photo from desktop
  2. Step 2 Wait for 30 seconds
  3. Step 3 Please Photo does not do anything after auto pilot has finished.
Topaz Photo AI [v2.3.2] on [Windows/Mac]
I’m experiencing the same thing.
Mine seems to work fine if you drag and drop the photo into Topaz Photo AI.
Is that the same for you?
Same issue very slow or stops when importing from lightroom or drag and drop.
Topaz Labs Download Page
Let me know how that goes for you and I’ll keep an eye out for your reply.*
Thanks John. Since uninstalling the previous version and upgrading to the latest, the program has been working much better. I haven’t had the courage to try batch processing, but it works well for one photo at a time.
