Topaz Photo AI 2.2.2 - freezing and lagging
Hello Topaz Labs,
I am sure you are already informed by manny clients that Photo AI is not running smoothly for some time already… I did experienced on 10th of January and i was hoping you will managed to fix that problem. Before that date it was working normally with no issues at all even with all previous versions, and now with 2.2.2. is very bad experience to work with it. I am using Topaz Photo AI on macOS Big Sur ver. 11.7.10. Mac Pro. I am looking forward that you will fix this bug very soon. Thanks in advance.
You can securely submit your files(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Hello John,
thanks for reaching out to help me solve the issue with the latest Topaz Photo AI that i have. Even with the new version I am still experiencing same issue that Topaz Photo AI is very slow, freezing and lagging… With the version before 2.2.2 I didn’t have any problems and it was running very fast and smooth.
I just imploded you my sister profile file and I hope that you can figure out what I need to do in order to have Topaz Photo AI running again smooth as before.
Thanks again,
Petar Pecanac
Topaz Labs Download Page
Hi John,
Thank you for the help on this ticket.
I did exactly what you told me and now Photo AI is working smooth again!
Thanks again
Petar Pecanac
