Topaz Photo AI 2.0 Stops Processing
When opening an image through the File->Plug-in Extras menu, the photo opens and gets stuck about 1/4 into DeNoise. The screen is not frozen and I can continue to move the image around, but it never processes or even starts over after moving the image. Note, it DOES NOT crash.
Steps to reproduce issue:
  1. Open Raw File in Lightroom
  2. Open Raw file in Topaz Photo AI using the Plug-in Extras Menu
  3. Wait
Topaz Photo AI [2.0.0] on Windows
Thanks for reaching out. Please reproduce this issue.
When it happens again, open Topaz Photo AI, go to the menu bar on the top and click the Help > Open Log Folder menu option. Attach the last 3 log files you see so I can check the contents and figure out what is happening.
Seems to have cleared up with the new version.
I believe I’m having the same issue with 2.0.1:
@john.dubicki Our developers are currently investigating this. Please upload the log files so we can use it for troubleshooting.
It started doing it again even with the latest version.
Please open Topaz Photo AI, go to the menu bar on the top and click the Help > Open Log Folder menu option. Attach the logs to your reply so I can check the contents and figure out the cause.
