Topaz Labs
Please send a normal build of version 1.9 or lower, I pray you. Upgraded to version 2.0.1, works 10 ± photos, and then starts to lag and stand still, nothing happens. Regardless of what kind of photo, and in what quantity. The power of the computer is enough for everything. Before version 2, everything was fine. So I demand to send me any other version, the younger 2.
Here you find the older versions: Releases - Topaz Community
Thank you so much !!
If you update to the latest versions and you are still having issues, open Topaz Photo AI, go to the menu bar on the top and click the Help > Open Log Folder menu option. Attach the logs to your reply so I can check the contents.
This should help me figure out what the issue is.
