Topaz Labs Photo AI unresponsive and freezing
Try to include logs (Help → Logging) - not present in current version its help open log folder
2024-03-28-17-36-4.tzlog (176.6 KB)
2024-03-28-17-37-40.tzlog (81.2 KB)
2024-03-28-17-40-22.tzlog (874.7 KB)
2024-03-29-09-57-36.tzlog (116.5 KB)
2024-03-29-10-01-7.tzlog (240.1 KB)
Steps to reproduce issue:
  1. with Lightroom open and then I click on edit with Topaz Photo AI in the Edit with Dropdown menu when right clicking on an image in Lightroom, then selecting make a copy with Lightroom adjustments then clicked on edit. (file type is tiff uncompressed in prophoto colorspace(
  2. wait for topaz to finish the autopilot (once topaz photo ai is open the freezing of the view pane and unresponsiveness is already started)
  3. wait for generating preview to finish (Takes an abnormally long time)
  4. near complete unresponsiveness
Topaz Photo AI [v2.4.2] on [Mac with Apple Silicon M1 Max]
2024-03-29-19-15-37.tzlog (255.1 KB)
2024-03-29-20-19-17.tzlog (99.6 KB)
2024-03-30-11-15-3.tzlog (128.3 KB)
2024-03-30-11-20-38.tzlog (25.9 KB)
2024-03-30-11-27-13.tzlog (99.9 KB)
2024-03-30-11-35-45.tzlog (138.8 KB)
Filter Plugin Log.txt (4.3 KB)
lastSessionFiles.txt (69 Bytes)
First make sure that you have Lightroom and other plugins fully closed before proceeding.
Topaz Labs Download Page
