TOPAZ is very VERY slow after a few updates (Macbook Pro)
TOPAZ was a very fast programm unill a few weeks ago. After updating it is too slow now.
It runs on a macbook pro.
It’s possible you’re missing model files. Please follow the steps below to fix this.
  1. In MacOS System Settings > Privacy & Security > Files & Folders, find Installer and enable all locations for it.
  2. Run the Topaz Photo AI installer. You can download a new installer from the downloads page directly. https://topazlabs.com/downloads/
Let me know if that works.
Which model are you using?
Iris on MacOS is in fact much slower than what would be possible / than it was before after the last model updates.
The other models do perform normally.
See this thread:
@tim.he
Any news on when the Iris performance will be back to normal?
I have a MACBOOK Pro M3 MAXX at the highest specs - TOPAZ AI V3 is incredibly slow! There is something wrong with the software upgrade and I have no idea what is happening. If this is not resolved in a short time, I can no longer this software.
