Topaz gigapixel stuck "updating" for days
“downloading models”
“some model files need to be re-downloaded before images can be processed”
Progress bar half-way through. beeen stuck for days. Tried relaunching program, same problem, no joy
Hi.
This has happened because, the connection was interrupted during the downloading and installation process possibly, due to a VPN, Firewall, Proxy, or antivirus.
Disable them one at a time one and try once again
Here’s the link if you wish to contact Topaz Support
Topazlabs Support
support@topazlabs.com
Hope this helps
that is incorrect, having the same issue and I know none of those issues is the cause for a fact, going to post my own Topic, just wanted the OP not to be uninformed
edit: figured out how to solve the bug in my case at least, got the error, hit ignore and switched to 1x and did a preview and it worked, after that the other sizes worked as well
