I’m new to Topaz Denoise. It’s an amazing product, which I cannot stress enough! However, there are some behaviors that I don’t understand. Maybe these are caused because I’m still on the trial version. Is that different from the fully licensed version?
When opened from within Lightroom, Topaz Denoise shows different menu options than if it is opened stand-alone. For example, “Save As” is missing. Also, naming preferences previously specified in the stand-alone version (add prefix/suffix) are not available and not applied.
Topaz Denoise messes up my exif Exposure Bias. If I have a RAW (CR2) file with 1/2 EV, Topaz Denoise changes it to 1073741823/2147483647 EV in the output TIF file’s exif.
When Topaz Denoise is opened from within Windows Explorer, by right-clicking a RAW file (CR2 or ARW) and selecting “Open With”, it tries to save the output file with its original RAW name. When I inspect the original RAW file’s properties, nothing seems to have changed (luckily). I am unable to locate any other version of the RAW file with a 'Date Modified" that is different from the original. It seems that Topaz Denoise actually didn’t do anything.
I read somewhere that Topaz Denoise creates artifacts. After carefully inspecting a before and after image I now think that it simply makes artifacts more visible by denoising and sharpening. It would be great if an artifact-search-and-repair could be built in, somewhere in the future.
Maybe some of the above are explained in the User Guide. However, I cannot locate it. Can someone point me the way?
