Since a few weeks, I can’t use Topaz photo AI anymore.
This is happening from lightroom but also when I use the app separately.
I reinstalled topaz and reinstalled (3.3.2) but the probleme is the same
Steps to reproduce issue:
I start Topaz photo AI → OK
I m ask to drag/drop an image or browse image → I pick one
The photo appear in the central part of the screen 1 second and the application stops with out error message
Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
I just sent you via drop box the files that you asked.
Config as you will see is 16 G Ram, Core i7.
The last vestion that works on my computer is the one released past august. Any version after is crashing without error message as soon as I load a photo (even a very small jpg) → I can get any updates.
I re-installed today the latest version to recreate the crash and related logs and I will go back to the old version just after
