Topaz AI V2.2.1 SLOW
Anyone else seeing the 2.2.1 release as being drastically slower to process?
MacBook pro.
2.9ghz quad core i7
Radeon Pro 560 4gb
16bg ram
Not for me. Maybe your GPU needs updating if you are on a PC. Or your systems specs just can’t handle it. Without knowing what these are, no-one can help you.
I am on an M1 Mac Mini, 16GB Ram, Sonoma 14.3.
MacBook pro.
2.9ghz quad core i7
Radeon Pro 560 4gb
16bg ram
You don’t say, but a quick search indicates that this is a 2016 or 2017 model. I am by no means an expert, but I have always worked on the assumption that if a computer is more than five years old it may not be able to handle the intensive AI tasks of the latest software.
Topaz don’t seem to state minimum specs, but I suppose you could ask Support this. Also, do you have plenty of free space on your drive? If it’s running low, this can sometimes slow down performance.
Oh yes they do: System Requirements | Topaz Photo AI
2TB free. No reason the equipment on this mac cant handle this. It did prior to this update. thanks for your feedback.
Not slow on my Win11 pc. Just done PAI on 872mb file, took a few seconds to save.
