Topaz AI v2.01
Use this as a plugin with Affinity Photo 1.10 . Worked fine until i upgraded to version 2.01 , now crashes when i try to invoke the plugin . , My processor is a AMD Ryzen 3 2200G with Radeon Vega Graphics 3.50 GHz Hope you can sort this out soon
Can you upload the log files so I can see what’s going on in the application. To do that, open Topaz Photo AI and go to the Help > Open Log Folder menu option and upload all the logs in the folder.
Also, here’s a link to update your graphics card drivers in case they need optimizing: https://drivers.amd.com/drivers/installer/23.10/whql/amd-software-adrenalin-edition-23.9.1-minimalsetup-230905_web.exe
I had another user report this same issue. Please try following the instructions they shared to fix it.
