When using the remove noise functionality, if the photo is cropped, the AI algorithm makes the photo very mushy.
There should be an option to apply the remove noise filter only to background (excluding the subject).
Steps to reproduce issue:
Step 1
Crop the photo in other software
Step 2
Apply the Remove noise filter in Topaz AI
Step 3
Observe that the subject has lost details and looks mushy.
I tried adjusting the strength of the Remove Noise filter, but that didn’t help…
Also, let me rephrase my problem - when scaling up and using Remove Noise filter, the picture appears mushy.
If you have Upscale turned on as well, you may want to decrease the Upscale - Minor Denoise to the lowest setting to avoid removing too much detail from the image.
