Topaz AI Products in the Start Menu
Hi there, when installing Topaz AI it asks … what start menu you want it put in … what should I be doing here? I have LR, PSE and Studio 2. I would like to use it in PSE and Studio 2. Thanks for any help.
I guess you are on windows? If you are the Start Menu referred to the Windows Applications menu.
That is not given as an option.
For what it’s worth, I usually uncheck that option and then ignore it. At a later point in the installation I think you get a notification of which apps it will be installed as a plug-in to.
Rest assured the Start Menu is the default Topaz Labs LLC in the Windows Application Start menu and you can change it if you like.
If you are talking about installing as a plugin it is part of the install process that it installs in apps such as LR and PS. And make sure you run it as a standalone the first time.
Ok, didn’t realize you could bypass this so thanks :blush:
